Re: TI coils vs. regular
If more than one spark is required, there's something wrong with the system design.
Car manufacturers always use inductive ignition systems because they generate long duration sparks, which is the best type of spark to ignite lean, low density, or exhaust gas diluted mixtures, which is typical of road engines that spend most of their at relatively low load or idling.
CD ignitions have very intense, but short duration sparks. They work very well with rich, high density mixtures typical of racing engines at WOT, but not with lean, low density, diluted mixtures.
The GM point ignition spark duration is about 120 microseconds. TI and HEI are about 180, but the CD system from the late sixties was only about 35, and the MSD system is probably about the same. Though it generated "multiple sparks in the low to mid rev range, if the first one doesn't light the fire, the second is considerably retarded.
