70 carb date vs engine build date - NCRS Discussion Boards
  • William B.
    Infrequent User
    • November 1, 1996
    • 5
    My 1970 350 has an engine build date of Feb 4. What dates are acceptable for the Q-jet carb for NCRS judging? Thanks.
    • 15630
    Re: 70 carb date vs engine build date
    The carburetor was installed at St. Louis, so the relevant date is your body build date, not the engine assembly date. For early C3s we use the date on the trim tag as the assembly date. You need a carburetor dated six months or less before that build date.
    That date code for 1970 Corvettes (stamped after the word CHEVROLET on the upper right hand corner of the trim tag, which is above the upper hinge of the driver's door) will be B = February with the following two numbers being the day of the month.
    • William B.
      Infrequent User
      • November 1, 1996
      • 5
      Thanks, Terry. The build date on the trim tag is B14 so a carb dated Jan 14 (0140) should be OK, right? Thanks so much.
        • 15630
        Absolutely! Congratulations; from a date standpoint you have a winner.
        • William B.
          Infrequent User
          • November 1, 1996
          • 5
          Thanks, Terry, and thanks for all you've done for NCRS.
