Original engine??? - NCRS Discussion Boards
Original engine???
  • Houston U.
    • June 30, 2000
    • 75
    Original engine???
    Back on Jan 30th, I posted info to confirm my '66 Coupe originally 327 300 hp. I've just returned from Haiti (Search & Rescue) and have additional info. My stamp pad is 6124450 F0520HH (pad length = 3.5 "). 3858174 = 1.5" and GM = .75". It was delivered to Harry Mann Chevy in LA, CA. The plate reads: K07 Detroit, MI, A-4516 Body, Trim: Std., 19437. 982 paint. Block cast is C 28 6. Here's the update. On the front of the block it has the following markings. Upper right corner:
    N 29
    852
    Lower right corner:
    HB
    Next to cam opening:
    G17
    Lower left corner:
    174
    362
    Bellhousing end has the following:
    H5
    174
    HB
    G852 (maybe C).
    I'm wanting to represent this sale as truthful as I can. Your expertise is greatly appreciated.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Original engine???
    Welcome Home, Houston !!!!
    I don't know the VIN of your car, but assuming it is the same as the number indicated on the engine stamp, I would say your sequence of numbers indicate a correct application. Is it original ?? I don't know, but I would guess yes, unless you suspect somebody restamped it.
    March cast block. Assembled in May. Installed in a June A.O. Smith bodied car.
    Looks good to me.
    Then again, I always seem to miss something. Wait for more replies before you take mine to the bank !!
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
