1974 Q-Jet 7044206 vs 7044202 - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    The former is for a 1974 L-48 with A/T (non-CA) and I believe the latter is for a Chevelle with A/T (non-CA). Does anyone know if the latter will work OK on a base 350/195 1974 Corvette? Looking at jet specs etc. they seem identical. What is the difference?
    • 6950
    Re: 1974 Q-Jet 7044206 vs 7044202
    Paul, the 7044202 I believe is the correct carb for your corvette, the 7044206 maybe a replacement number.I think that the last 3 digits 202 are a common number that is seen for a L-48 Corvette w/auto. the number (4) is the year.
    • Paul L.
      • November 1, 2002
      • 1414
      Ed,
      I was going by the Black Book and it says ...206 is correct. But I have a rebuilt ...202 coming in for the 2010 season from a reputable source here in Canada. Apparently this is a Chevelle carb but I agreed to its purchase. My research indicates that the jetting specs are the same. I am sure it will work fine but I am curious as to what the differences are.
      • Martin N.
        • July 30, 2007
        • 594
        PAUL-
        Try www.carburetion.com/quadnumber and see if that'll help you at all.
        Marty
          • 6950
          Paul, my 72 L-48 Carb. no is 7044202, which is correct for for my base engine. there is a website that has all the carb. no.'s listed for all gm cars you maybe able just punch in the carb. # and do a search.
            • 6950
            Paul, the carb no. is as you posted is correct 206, the, I think the only difference may be the chevelle trans. may be a turbo 350, hence may have a kick down cable attachment. the 400 does not.
            • Martin N.
              • July 30, 2007
              • 594
              ED-
              I posted no carb number.
              Marty
                • 6950
                Sorry Martin, I Corrected My Post.
                • Paul L.
                  • November 1, 2002
                  • 1414
                  OK, that may be it. If so, no problem. No cable, no problem. Nothing to connect. Yes I have a TH400 with the gas pedal activation. I wish I could convert to cable activation but that is another thread.
                  • Paul L.
                    • November 1, 2002
                    • 1414
                    Originally posted by Martin Novak (47651)
                    PAUL-
                    Marty
                    Check the specs here. The ...202 and ...206 seem to be identical?
                    • Martin N.
                      • July 30, 2007
                      • 594
                      PAUL-
                      Are you after replacing a carb that's not quite right or something with a little more punch? Why not have the original(?) rebuild and keep what ya got.
                      By the way nice and informative site, I booked marked it....THANKS.
                      Marty
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        if you are still interested e mail me after the first week of march as i will be back home in Pa. where my info is located
                        • Paul L.
                          • November 1, 2002
                          • 1414
                          PAUL-
                          Marty
                          That's the plan. A core was not requested for the purchase. I have a rebuild kit with blue Viton components.
                          I suspect that modern gas has chewed up the black rubber components in mine.
                          The new unit will be set to factory specs.
