89 Passenger Side Half Shaft ID Plate? - NCRS Discussion Boards
  • Peter M.
    • April 8, 2007
    • 570
    Can anyone decode the numbers on the plate attached to the passenger side half shaft on a 1989 C4? I am trying to decode the factory tag attached to this half shaft. Attached is a photo of the tag (click to enlarge).
    Any help will be appreciated.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 89 Passenger Side Half Shaft ID Plate?
    Hi Peter !
    I know the 10054290 is the part number. Now discontinued. I'm not smart enough to decode the rest.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      • 15616
      Just some SWAG:
      8YP looks like a broadcast code. If one had the build sheet the answer might be obvious.
      1408 looks like it might be a date code. Maybe the 140th day of 1988. Would that work for your car?
