Re: grease fitting on power steering
I have gotten out all of my Valve & Adapter Assembly drawings and reviewed them. I now believe that I made some incorrect conclusions regarding zerk fittings and ball stud seals.
I have a Valve & Adapter Assembly drawing 7825636 which indicates its first useage as the 1976 Corvette. (Drawing date was 11-20-74 and Engineering Release date of 3-12-75). I believe that it is the latest and last valve & adapter part number for the C3 Corvette. I don't think that Joe Lucia's records indicate any later valve part numbers.
This drawing has revisions as late as 1-25-88 so it was kept up to date through the years. It shows a zerk fitting and a purge slit in the ball stud seal nipple with no revisions throughout its drawing life (1974-1988). This would indicate that the zerk fitting was never eliminated from the valve.
Also, I have an early valve & adapter drawing (5691955 dated 7-11-62) which also shows a Zerk fitting. That same drawing shows a ball stud seal revised and a purge slit added 2-19-75.
So from the above information, I am led to the following conclusions:
1). Zerk fittings were always installed on the adapter, (even if the valve was "greased for life"). Possibly the Zerk was needed to fill the ball stud cavity (either at Saginaw or possibly at St. Louis/Bowling Green?).
2). Valves before 1975 did not have the purge slit in the ball stud seal. I now believe that the purge slit may have been added to act as a pressure relief valve (it allows excess grease to escape and prevents high pressures from damaging the valve seals.) The purge slit may not have had anything to do with "greased for life" edicts from General Motors.
BTW, here are engineering revision dates for some other valve changes. (The revision dates are not necessarily production dates.)
Stamped "C" eliminated from the end cap (Revision A dated 7-20-77).
Two bolts that attached the valve to the adapter changed from 180123 (12 point) part number to 178940 (hex), (Revision C dated 3-20-79).
Jim Shea
Jim Shea
