'66-'67 grease points - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7145
    I got my grease gun out to grease the cars today. I couldn't find the points to grease in my assembly manual, but looked all under the car and found the ones on the steering and the clutch. I don't see any others, am I missing some (like U-joints) or not? Thanks for any tips.
  • Rich P.
    • January 12, 2009
    • 1361
    Re: '66-'67 grease points
    Michael,
    Original u-joints don't have grease fittings. If yours have been replaced with greaseable ones then do them. don't forget to do the upper and lower ball joints.
    Rich
    • Michael J.
      • January 27, 2009
      • 7145
      No fittings on the U-joints, guess that is correct and they haven't been replaced. Right, those ball joints, those suckers hide behind the wheels and splash shields in the engine compartment. Thanks.
      • Dave B.
        • April 30, 1984
        • 248
        Don't forget the Tie Rods.
        Dave
        • Joe R.
          • May 31, 2006
          • 1822
          Michael,
          It sounds like you may be working without benefit of the Corvette Shop Manual (CSM). I would recommend getting one, it has a diagram that shows where the grease fittings are located.
          Joe
          • Chuck S.
            • April 1, 1992
            • 4668
            Originally posted by Joe Raine (45823)
            ...It sounds like you may be working without benefit of the Corvette Shop Manual (CSM). I would recommend getting one...
            Joe
            I agree.
            Joe, the acronym "CSM" used here by Duke and others actually stands for "Chassis Service Manual", which is the title of GM service manuals. In those days, the GM service manuals published by Helms, Inc covered ALL the Chevrolet car lines.
            There was/is also a companion manual called "Chassis Overhaul Manual" which goes into greater detail for component overhaul.
            • Michael J.
              • January 27, 2009
              • 7145
              Michael,
              Joe
              Joe, the CSM is the first place I looked, but the diagram and lines disappearing under the schematic car as less than informative. I just wanted to be sure where to grease, sometimes a picture is not worth 25 words or less. This diagram also didn't show the PS ram grease point others have recommended greasing.
              • Chris E.
                • November 3, 2006
                • 1331
                Make sure the fittings are clean before you grease them. I was told that on the C4s, the only grease points were the upper and lower ball joints. All others were removed because premature failure happened when greasing a dirty fitting.
                Chris Enstrom
                2011 Z06, red/red
                • Michael J.
                  • January 27, 2009
                  • 7145
                  Good tip, I learned that when I worked in a garage at 50 cents an hour in high school, but some I worked with didn't seem to learn very fast. Or they just wanted more business when the poor customers came back fo more expensive repairs
                  • Joe R.
                    • May 31, 2006
                    • 1822
                    Chuck,
                    That's what ah said! Just kidding, thanks for the correction.
                    Joe
