Help rear spring mounting kit - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    Re: Help rear spring mounting kit
    Thanks Joe will try it without. I will measure front bar.
    • Timothy B.
      • April 30, 1983
      • 5194
      If those trailing arms are offset in, when the spring flatens with the weight of the car the interference with the long bolts will become worse.
      Maybe it's me but something does not look right.
      • Wayne P.
        • January 23, 2008
        • 444
        #18
        Thanks Timothy I will try and find out. I believe the offset is only at the front of the trailing arm to allow larger tire. Do you know anybody with offset trailing arms ? I will ask Brian at Bair's corvette were I bought them.
        • Timothy B.
          • April 30, 1983
          • 5194
          #19
          Wayne,
          What you say makes cense and if that's the case I am not correct. I think you should pay attention to this, I don't recall mine looking like this.
