L79 carb jetting - NCRS Discussion Boards
L79 carb jetting
  • William F.
    • June 9, 2009
    • 1364
    L79 carb jetting
    What are factory primary jets and secondary metering plate numbers for 3810 Holley on '67 350 horse L79? Were they delivered for different altitudes? I'm at low altitude-300 Ft. above sea level?
    Re: L79 carb jetting
    Bill -
    #65 primary jets, .076" secondary (don't recall the Holley metering plate # offhand). There was no "altitude" version - they were all the same, and the same 3810 was used on both (base) 300hp and (L-79) 350hp applications.
    • Michael J.
      • January 27, 2009
      • 7175
      My '66 L79 has that carb, and it was moved from near sea level to my place near 7000 feet. I had no issues with the carb or the engine, runs perfectly and has for the last 2 years. My newly moved L71, on the other hand......
      • Gerard F.
        • June 30, 2004
        • 3806
        Bill -
        The secondary metering plate is a #22. Power valve should be a 6.5
        Jerry Fuccillo
