Aluminum manifold intake bolts - NCRS Discussion Boards
  • Stephen R.
    • May 20, 2008
    • 302
    Were aluminum manifold bolts used on the 2x4 aluminum intakes, and steel bolts used on the cast iron 1x4'S for C1 vettes?
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 292
    Re: Aluminum manifold intake bolts
    No. All intake bolts were steel.
    John
    • Stephen R.
      • May 20, 2008
      • 302
      John
      Thanks John. I have a set of aluminum intake bolts, any idea of what they were used for?
      • Jerry B.
        • August 31, 1994
        • 416
        Hello John, Do Not Forget The Special Washer In Order Not To Mess Up The Manifold.
          Steve -
          Do you mean you have intake manifold bolts you think are made of aluminum? In 38 years in the auto industry, I've never seen a bolt made of aluminum; they would be hopelessly inadequate for any automotive application, with not much more tensile strength than a pencil.
            • 43221
            Stephen------
            I'd suggest checking them with a magnet if you think they're aluminum. If there's strong magnetic attraction, then they're steel, probably with a zinc plate.
            Aluminum alloy bolts are available, though. They are used for specialized applications and as John Hinckley also noted, none were ever used for any automotive application. Mostly, I think they are used in the aerospace industry for applications not requiring much strength but where minimum weight is desired.
            • Stephen R.
              • May 20, 2008
              • 302
              Ah, here's my story. I was looking for a set of original intake bolts for my slooooowly being put-together engine which is mounted on the engine stand in the basement.....winter project....I have two intakes, a 1x4 and an aluminum 2x4. Haven't decided which way I want to go (or what I can afford), so I'm prepping for both.
              Saw a few sets of bolts for sale on Ebay, most of which were way too expensive (one set went for $125), but a guy was selling grade 5 circled AP "aluminum" intake bolts cheap, $10 plus shipping, so what the heck, I bought them. Figured maybe that they went on the 2x4. I just tried the magnet test and they are, in fact, steel, but they look like aluminum. Anyway, it's a nice looking set.
              As to washers, page 55 of my Corvette restoration book says washers weren't used.
              Thanks again guys.
              Steve
              • Rod K.
                • 443
                No washers, bolts are probably cad or zinc plated.
