Re Yoke help - NCRS Discussion Boards
Re Yoke help
  • Wayne P.
    • January 23, 2008
    • 444
    Re Yoke help
    I took the yoke off to replace the seal. I noticed the shaft end is very sharp. I assume it has been rubbing metal on metal. Was their suppose to be a oil baffle washer in front off bearing ? I assume I will have to find a used Yoke. Thanks for any help 1964
    • 43246
    Re: Re Yoke help
    Wayne-----
    There is no washer, oil baffle or otherwise, inboard of the flange.
    • Paul D.
      • September 30, 1996
      • 491
      Re: Re Yoke help
      Wayne,
      Why do you feel the yoke needs replacing? Unless the splines are loose on the pinion gear or the surface the seal rides on is grooved, I would think you could reuse that yoke. Or maybe I am missing something. Chip
      • Dick W.
        • 10483
        Re: Re Yoke help
        Originally posted by Paul Drennan (28344)
        Wayne,
        Even if the yoke is groved on the seal surface, you can buy a C/R Speedi Sleeve and get a lot more use from this yoke.
        Dick Whittington
        • Wayne P.
          • January 23, 2008
          • 444
          Re: Re Yoke help
          Thanks. The question came up from the transmission shop . They were concerned that the end of the shaft was very sharp with a slight bur.
          The spline is .052 above the worn part. I will look up the c/r speedy sleeve. The shop said their must have been a lot of load on it at one time. Taking the frame off I noticed that it was cut out for a big block at one time. Well I hope then that I can use it . Quite expensive to replace.
