install differential cushions - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    Does anyone have suggestions on installing differential cushions into crossmember ? what is the best way to bend the tabs over? Thanks for any help.
    • 43285
    Re: install differential cushions
    Brad------
    Make sure the bushing cavities in the crossmember are completely free of rust and dirt;
    Lightly lubricate the cavities and external shell of the bushing with silicone grease;
    Press the bushings in using an hydraulic or arbor press. If you don't have a press, you may be able to drive them in with a hammer. Press or hammer ONLY on the outer shell of the cushion and NOT the inner rubber portion.
    Bend the tabs over and flatten with a hammer.
      Brad -
      Just whack 'em with a ball-pein hammer to get them started, and finish with the flat end; it's pretty soft steel.
      • Brad S.
        • July 31, 2005
        • 227
        Thanks John and Joe, the crossmember has been blasted and painted . Is it necessary to remove the paint from the cavity in the crossmember to get the cushion completely seated?
        • Wayne P.
          • January 23, 2008
          • 444
          Brad my two cents worth . I just put a couple in . I had no problem installing with cross member painted. I used a block of oak and drove it in
          with a hammer. I put a small amount of white lithium around bore first.
          Bend tabs down flat with hammer stated. I had to touch up tabs with paint after install. I also sprayed inside cross member with rust proofing.
          Good luck.
