'69 wiper door bolt removal - NCRS Discussion Boards
  • Graeme B.
    • October 23, 2007
    • 213
    Hi all.I removed my wiper door and the bolts broke in the die-cast.They have a nylon insert in them to stop them from coming loose and this makes them weak. Any ideas for getting the suckers out???Thanks for any tips,Graeme.
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: '69 wiper door bolt removal
    Graeme, I don't remember any nylon inserts, only that the bolts that attach the door to the mechanism are shoulder bolts with a small threaded shank that's easily broken.
    I think your only option is going to be drilling them out very carefully. It's a tricky process because there is no place the door can be gripped in a vise without possibly damaging the casting, and the holes have to be perpendicular/square to the door ends. Even with care, I expect you will not be able to save the original threads; you're probably better off just drilling oversize and threading the holes for helicoil inserts to get fresh threads.
    • Dick W.
      • 10483
      Old Indian trick. Soak the bolt in penetrating oil of your choice for several days. Purchase a LH drill bit that is somewhat smaller than the bolt. Center punch the broken bolt and use a reversible drill to drill out the bolt. Quite often the LH bit will back the bolt out.
      Dick Whittington
      • Graeme B.
        • October 23, 2007
        • 213
        Thanks Chuck and Dick.I'll try these methods. Its amazing these were my only problem in stripping down the whole car for total resto.Cheers,Graeme from OZ.
          • 15616
          I think there is a nylon washer there, but I don't remember an insert or bushing.
