C3 front end link kit - NCRS Discussion Boards
  • William D.
    Infrequent User
    • 15
    Is there a replacement for the C3 front end link kit GM# 14101339?
    Bill 1969 roadster
    • 43273
    Re: C3 front end link kit
    Bill 1969 roadster
    Bill-----
    There's really no direct replacement. However, GM #88912149 will perfectly SERVICE the applications. There may be some slight differences in the configuration of the retainers and/or bushings.
    Another option:
    Purchase the above kit (it's not very expensive, anyway). If you don't like the configuration of the retainers or grommets, then replace with the following:
    GM #6270752---grommets
    GM #25628204---retainers
    The retainers will be the main issue. Once the grommets from the kit are installed, there will be no way to discern if they are slightly different in configuration from the originals.
      • 6956
      Bill, paragon corvette does sell a repo link kit thats as close as you'll get to the original .
      • William D.
        Infrequent User
        • 15
        Thanks, Joe.
        • William D.
          Infrequent User
          • 15
          Thanks, Ed.
