sunvisor restoration - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    I just purchased a set of '60 sunvisors which are in need of restoration. Are there any recommendations for this restoration?
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Don H.
    • December 1, 1981
    • 1491
    Re: sunvisor restoration
    I have never heard of someone repairing or restoring them (except dying). Because of the way they are built, it would be tough. New repros might be the answer. Don H.
    • Richard T.
      • February 1, 1979
      • 858
      If there are no split seams and the color is faded then you can spray dye them. The original hardware can be re plated and should be if it's not too bad. The repo hardware is different so re use the original if you can. Rich
      • Edward S.
        • December 1, 1986
        • 514
        You live in the Carolinas, if you get a chance stop into a shop that does boat interiors and let them take a look. I live 10 minutes from the ocean and at times over the years I have had various parts of my interiors redone in different color leathers and was pleased with the results. Good luck.
        • Valeria H.
          • July 27, 2009
          • 463
          Edward, your suggestion about the boat interiors shop just gave me a "TaDa" moment! I just called C Fredericks Auto Interiors here in Charlotte who will be working on the convertable top frame to try to straighten it out. He has been highly recommended here in the area by several knowledgable people. They do indeed repair vinyl rips etc.
          Thanks for the suggestion. Now I can take care of two issues at the same time.
          Valeria
          Valeria Hutchinson
