Wiper motor bench test - NCRS Discussion Boards
  • Michael G.
    • January 1, 1997
    • 1251
    Finally getting around to bench testing my '66 wiper motor however nutt'n happens after hooking it up. The procedure I'm using is:
    • Ground (12-) the case
    • Positive (12+) to middle terminal
    • Ground (12-) to inside terminal (high speed). Ground (12-) to outside terminal for low speed. However doesn't work on high speed.
    Nothing. Am I missing something here?
    Restorer David Gieske who did work has passed away . May need to source outside help....any suggestions there?
  • Steve D.
    • February 1, 2002
    • 990
    Re: Wiper motor bench test
    Michael
    See if this link helps
    [FONT='Times New Roman','serif']http://forums.corvetteforum.com/c1-and-c2-corvettes/2282494-need-help-with-67-wiper-switch-motor-wiring.html[/FONT]
    Steve
    • Joe R.
      • July 31, 1976
      • 4551
      Ground the terminal on the ww motor closest to the front of the car. That is high speed. That terminal and the one closest to the firewall is low speed. Center is always +12.
      If that don't work. PUNT!
      JR
      • Michael G.
        • January 1, 1997
        • 1251
        Appears I may need additional help.
        After making the connections with 12+ in the middle then grounding the outside terminal motor runs appearing to be low speed which is not right. Jumping the ground to back terminal changes nothing. Continues to run at same speed which as stated appears to be low speed .
        • Tim E.
          • April 1, 1993
          • 360
          Michael - See if this helps....it's the bench test procedure I used with my '66. Tim
