1972 shock broadcast codes - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    What are the shock broadcast codes for 1972 LT1?
  • Kevin G.
    • February 1, 2005
    • 1077
    Re: 1972 shock broadcast codes
    Jerome, Pg. 104 in the 70/72 JM calls out the codes, front PE rear PY w/F41 front PF rear PR
    Kevin
    • Jerome P.
      • October 22, 2006
      • 607
      Kevin
      Thanks Kevin. I just missed it in the JM.
      • Jerome P.
        • October 22, 2006
        • 607
        Kevin
        Again thanks Kevin. One other question. Do you know the location of the broadcast code labels on both the front and rear shocks. Standard suspension.
        Thanks again.
        Jerry
          Thanks again.
          Jerry
          Jerry -
          Where the Chassis judges can see them - rears facing rearward, fronts facing forward; on the rears, they go on the upper (shield) portion of the shock.
