Distributor oiling tube? - NCRS Discussion Boards
  • Edward M.
    • November 1, 1985
    • 1922
    OK, yet another question. The oiling tube on my 1110872 distributor is 180 degrees different than the oiling tube on a 1110879 distributor.
    I would expect that the oiling tube would come out of passenger side of the distributor (as installed in the engine), then take a 90 degree turn FORWARD toward the front of the car, then take a 90 degree turn up.
    The oiling tube on my 872 comes out of the passenger side of the distributor, then takes a 90 degree turn BACKWARD toward the rear of the car, then takes a 90 degree turn up. This puts the oil cap for the tube behind the distributor.
    Anyone else with an 872 distributor (or an 879 for that matter) with an oiling tube pointing toward the rear?
  • Roger W.
    • January 29, 2008
    • 569
    Re: Distributor oiling tube?
    What year is the distributor ? I have a tach drive single point distributor and the oil tube comes straight out on the passenger side. The band with the part number is missing. I would like to know how to tell what year or what the part number might be?
    • Edward M.
      • November 1, 1985
      • 1922
      1110872 and 1110879 distributors are both 1956 year only.
      A tach drive distributor with a oiling tube / port sounds like a 1962 distributor. I think that is the only year that both tach drive and an oiling tube / port occurred on the same distributor.
