1954 Carbs - NCRS Discussion Boards
1954 Carbs
  • Randy G.
    • March 31, 2006
    • 358
    1954 Carbs
    All three are complete except two of them are missing the choke assemblies (shafts, butterflies, springs, linkage pieces). Also, each has a 1/4" hole drilled where the air cleaner set screw would normally go against the carb tops to allow the set screw to penetrate the top of the carb to keep the air cleaner on. Other than that they are in good condition and the car runs fine.
    I want to have them restored (recolored, etc.).
    My question is, who would you recommend for restoration of the three carbs, and would missing parts be an issue or do I need to try to round them up? I want to have this car judged in the future so I'm curious to know if the holes should be repaired or if the carb housings will need to be replaced because of the small holes.
    Thanks!
  • Gary C.
    Administrator
    • October 1, 1982
    • 17547
    Re: 1954 Carbs
    Randy, give Gary Hodges a call 503-588-3883 Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Randy G.
      • March 31, 2006
      • 358
      Re: 1954 Carbs
      Thanks, Gary!
