Rear Brake Line Replacement - NCRS Discussion Boards
  • Edward S.
    • January 29, 2010
    • 22
    Is it possible to replace the steel brake line from my power brake master cylinder which runs through the frame and over the rear cross member without lifting the body off the frame?
  • Michael G.
    • March 2, 2008
    • 487
    Re: Rear Brake Line Replacement
    Ed, Check the archives (accessible from the main page of this forum) using "brake" or "fuel lines". I'm not familiar with the differences between C2 and C3 (if any) in the routing of these lines. You should find helpful info on this task but may be on the C3 only. I have done this on my 71' with body-on and welded trans crossmember. Brake line was easy as compared to the fuel and vapor lines, but they too are possible with every ounce of patience you have. Good luck, Mike
    • William G.
      • April 1, 1978
      • 154
      Ed
      What year our you trying to put the brake line on
      Bill
