69 posi rear axle - NCRS Discussion Boards
69 posi rear axle
  • Jim M.
    • February 23, 2009
    • 233
    69 posi rear axle
    I was thinking today that maybe it would be a good idea to change out the fluid in the posi traction rear end and the the tranny fluid. However, looking at the rear axle it appears to me that there is no drain plug and if that is correct, I'm guessing the back plate must be removed and to do that, it looks like the rear leaf spring also needs to come out. Hope I'm wrong because that sounds like a real PIA just to replace the fluid.
  • Paul D.
    • September 30, 1996
    • 491
    Re: 69 posi rear axle
    Jim,
    Most people use a suction gun to pull out the old gear lube. Be sure to use proper lube. I like to use the GM lube and additive, but I am sure there are others that work well also. Chip.
      • 43272
      Jim-----
      DO NOT loosen the cover bolts to drain the fluid. If you do, you're very likely to have a leak at the cover-to-carrier interface thereafter.
      • Chuck G.
        • May 31, 1982
        • 2039
        As Paul said, you need a "slurp gun" or suction gun. They look like HUGE medical syringes.
        The metal bodies are about 3" diameter and 12" long. On one end, where a needle would go in a medical syringe, is a 8-10" length of tubing.
        You remove the square plug, put the tubing end in, and suck the fluid out. Adding fluid is the reverse process.
        You can use this tool for both the transmission and rear end. It's a VERY handy tool to have.
        Chuck
        • Edward M.
          • November 1, 1985
          • 1922
          I concur with the above "slurp" gun idea. Harbor Freight (and others) has them. They are cheap. They sort of look like grease guns.
          My recommendation is to put in two bottles (they are small) of GM posi-addative, they fil to capacity with quality gear oil. Get the GM stuff, not the stuff they sell at the parts stores.
          Then you get to go out to the parking lots and do a bunch of figure 8s.
          • Jim M.
            • February 23, 2009
            • 233
            Thanks everyone for your comments. Hadn't thought about sucking the oil out the fill hole, a much better solution. I'll take a look/see this weekend for one of those in my town. Sounds like a good project for a rainy weekend in the Northwest.
            • Chuck G.
              • May 31, 1982
              • 2039
              Corvette dealers and Corvette shops will usually have electrically powered "suction pumps" to suck the fluid out.
              Us "backyard" mechanics get to use the "manual" pump.
              That 80-90 wt. gear oil smells great too.
              Chuck
                • 6955
                Jim, one quick note, the colder it is the thicker the 80w90 oil is, if possiable drive the car to try and warm-up the fluid , other wise the suction pump will take longer.
                  Jim -
                  It's a LOT easier to get to if you remove the right rear wheel.
                  • Richard R.
                    • November 17, 2009
                    • 76
                    What type of a wrench do you use to get the plug out?
                    Do they make square sockets? I tried a wrench but their is on room to turn it. Any suggestions would be appreciated.
                    • Dick W.
                      • 10483
                      8 point socket works well
                      Dick Whittington
                        Sears has them (Craftsman).
                        • Richard R.
                          • November 17, 2009
                          • 76
                          Thanks guy's, your are such a great help!
                          Rich
