does the ignition shielding on a 1966 300hp 327 have bolts holding it or wing nuts. jack
1966 ignition shielding
Re: 1966 ignition shielding
Yes. But you'll need to be a bit more specific as to which piece of shielding. For instance, the top shield has both wing bolts and a hex head bolt. The side shields have the wing bolts, and the side or spark plug covers use wing bolts.
Its all called out in your AIM:
UPC U69
Sheets A7, A8, and A9
DonThe light at the end of the tunnel has been turned off.- Top
They are wing screws or wing bolts. Not wing nuts. A wing nut is what is holding your air cleaner lid to the carb.
Nuts and screws/bolts are not the same thing
And aluminum wheels for 67 should be called "Nut On's", not bolt on's.
- Top
Exactly
so then it would also be a body off restoration, not a frame off restoration
didn't you learn anything at HTHS
what about the difference between a lamp and a bulb?The light at the end of the tunnel has been turned off.- Top
- Top
Thanks Don, I confuse myself at times. I wondered what that thing that held the air cleaner on was, as I thought a "WING NUT" was a Red Wings fan downtown at Joe Louis Arena.
- Top
The distinction is gossamer and we're pushing on a rope trying to induce the general public not to use the terms interchangeably. But, when I used to visit GE and Westinghouse, designers were quite specfic...
A lamp is a completed physical assy that consists of globe, filament, base and contact(s). The term 'bulb' refers to the globe and base (the silhouette components of the lamp) without reference to the specific filament or contact components.
So, virtually nobody except those in design/manufacture give a hoot about a bulb, it's the lamp they want/need...- Top
Lighten up Jack,what about the difference between a lamp and a bulb?
it was meant as humor, and more for the people that use motor and engine interchangably
