69 fiber optics @ center console - NCRS Discussion Boards
  • Don W.
    • September 30, 1997
    • 492
    I have my center console apart for a different reason. I know only one of my fiber optic lights works. Is there anything I can do to clean or check the ends of the fiber optics while I have things opened up?
    Don
    • 43222
    Re: 69 fiber optics @ center console
    Don
    Don------
    I would just wipe the ends of the cables with a soft cloth. Then, make sure the cables are securely "plugged into" the lens orifices. If they end up being rather loose (as is common), then use a piece of electrical tape to ensure they "stay put".
    Most likely, if you have fiber optic light transmission problems, the root cause of those problems is on the other end of the system.
    • Michael B.
      • June 18, 2007
      • 400
      If you have the fiber ends out of the lens look at the ends with the lights on. Headlights on bright and the flashers on. If the fiber and the lens on the other end are OK you will see the light. (pun intended) If you can see light you have a problem with the console lens. If you cant see any light then you have problems with the fiber or lens at the other end.
      For some reason GM decided to use a prizim effect on the LR console lens. It will always show dimmer than the others.
