Dates - NCRS Discussion Boards
Dates
  • Houston U.
    • June 30, 2000
    • 75
    Dates
    I'm having to sale my 66 coupe and when I bought it in 1988, the engine block was sitting in garage. I placed crate engine for driver and never worked on 327 block. Now I need to sale, I just want to be honest with buyer. I don't know if block is original, here's the dates/#s. If these are red flags, I'd appreciate it. Body Built Date: K07. A.O.Smith A-4516. Engine Pad has correct Vin # with F0520HH. It was delivered to Harry Mann Chevy, Los Angeles, CA on June 30th. (This was stated, not documented). Block Cast: 3858174, C 28 6. Transmission is P8P12 M-20 (I know it isn't original) Thank You!
  • Joe R.
    • May 31, 2006
    • 1822
    Re: Dates
    Houston,
    What is the last five digits of the VIN if you don't mind my asking?
    Joe
    • Lynn H.
      • December 1, 1996
      • 514
      Re: Dates
      The casting number is correct for 66 327 Corvette block, although the dates seem to have some time in between. With a March casting date and a May assembly date, although it falls within the 6 month window seems to be longer than I would expect to see on MOST applications. Although, there can be many variables that can come into play. The VIN would be helpful in determining, and if you could post a photo of the stamp pad on that block, I am sure you will get some good opinions as to originality.
      Lynn
      • Houston U.
        • June 30, 2000
        • 75
        Re: Dates
        Joel. the last four are 4450
        • Houston U.
          • June 30, 2000
          • 75
          Re: Dates
          Joe and Lynn,
          Sorry for the confusion of name. I'll send pic of stamp pad as soon as I can. Thank you for your time and consideration.
          • Houston U.
            • June 30, 2000
            • 75
            Re: Dates
            I hope this works. Please provide your expertise.
