60 Ignition shielding question - NCRS Discussion Boards
  • Chuck W.
    • May 31, 2002
    • 257
    Does anyone know if the lower ignition shielding mounting brackets (angle brackets on the exhaust manfold bolts) were installed on a '60 no radio car?
    Re: 60 Ignition shielding question
    My gut tells me that if you flip your copy of the AIM book to the radio option section in the rear, you'll find the shield support brackets are called out there. That says they should only have been installed on radio equipped vs. base cars...
    • Chuck W.
      • May 31, 2002
      • 257
      As usual.... Thank you Jack.
