'69 wiper motor wiring - NCRS Discussion Boards
  • Graeme B.
    • October 23, 2007
    • 213
    Hi all,does anyone have a wiring diagram for a '69 wiper motor ? Trying to work out the resistor and the short wire attatched.Thanks,Graeme.
    • 6960
    Re: '69 wiper motor wiring
    Graeme. I believe that resister wire one end is gounded to the motor housing, and the other end is attached the terminal board(has 3 terminals). the end that grounds to the motor has a loop, and uses one of the washer housing bolts. the other end connects to #3 termail on board whick is a black wire.
    • Graeme B.
      • October 23, 2007
      • 213
      Thanks very much Edward.I'll ground that wire. Cheers from OZ,Graeme.
