Clock Repair and Trim rings - NCRS Discussion Boards
  • Joseph K.
    • August 26, 2008
    • 407
    I need the name of a good clock repair person or service for a 69. Also someone said there was a person in Utah that could repair trim rings. Anybody know his name/email/phone Number? Thanks for the info
  • William C.
    • July 15, 2009
    • 239
    Re: Clock Repair and Trim rings
    Trim Rings, Rick Miller, #12282, 435-668-7062. I have purchased 2 sets for 67's and they were both outstanding.
      • 6956
      Joe, there is a few listings in the driveline for clock repairs, I know there is clocks by roger he does rebuild them also,But would say use one of the driveline advertisers that support our cause.
      • Joseph K.
        • August 26, 2008
        • 407
        Thanks for the info I found several in driveline.
        • Don L.
          • August 31, 2005
          • 1006
          I've previously used CLOCK WORKS in Wisconsin with good success. Think they are advertising in the Driveline under the following:
          Jerry Magayne (NCRS member 23253)
          1745 Meta Lake Tr.
          Eagle River WI 54521
          715-479-5759
          Good luck on the project.
          Don Lowe
          NCRS #44382
          Carolinas Chapter
          • Glenn D.
            • May 31, 2002
            • 137
            I purchased a repair kit from http://www.clocksandgauges.com/gpage.html
            and rebuilt my clock. It's not a difficult job. They also have a repair service.
            • Jim H.
              • January 1, 2005
              • 52
              Joseph;
              http://www.pcfred.com/Vettetip/FixC3Clock.htm I used the data attached to this link to fix the clock out of my '69. If you follow each step these instructions are exact and very good. I did my own repair after calling several clock/instrument repair places w/o ever getting a call back (used them before) - we're in a recession right? Generally, the Corvette clocks that I've fixed ('66 and '65) are not broken, but need cleaning and lubrication. You can bench test the clock simply by using a 12V car battery. My '69 works perfect and it's kind of fun to get them running.
              Good luck,
              Jim
              43119
