carburator help - NCRS Discussion Boards
carburator help
  • Jim T.
    • March 1, 1993
    • 5351
    carburator help
    Installing a carburetor renew kit in my Holley 650 6210 spreadbore Qjet replacement I needed something to support the carburetor body to install two 12/24 HeliCoils because the threads in the body were stripped. Needing something I could support the inverted carburetor body to first drill out the screw holes and install the HeliCoils.
    I tried a large steel coffee can that was in my garage and it worked perfectly. The later steel coffee cans have a lip at the top of the can to attach a heavy foil seal you peal off to use the coffee. I will keep this one around instead of putting it in the metal recycle bin. Sure made the job easier.
