After Rebuilding The Engine On My 71 Lt-1, I Was Running In The Cam. After About A 1/2 Hour, I Ran Out Of Fuel. I Looked At My Gas Tank ( Body Is Not On The Car ) And Noticed It Was Caved In Top And Bottom. Obviously I Have A Sticking Fuel Separator. I Didn't Realize A Fuel Pump Had That Much Suction! Can I Drill A 1/8 Hole In The Back Of The Separator To Fix The Problem? Will This Cause Any Issues With The Rest Of The Fuel Vapor System?
Also I Adjusted The Solid Lifters As I Have Always Done, Putting The Balancer Straight Up On #1 And Adjusting Ex. 1,3,4,8 And In. 1,2,5,7. Then Turning Balancer 1 Turn And Adjusting The Rest. I Noticed The Chevy Chassis Service Manual Has A Different Procedure For Adjusting Solid Lifters. I'm Not Sure Why This Would Be. Are My Valves Adjusted Properly The Way I Did It, Or Do I Have To Redo Them According To The Manual? I Appreciate Any Help On This. Thanks, Mark
