58 hand laid reproduction hood - NCRS Discussion Boards
  • Richard H.
    • March 1, 1985
    • 241
    I have a 58 hand laid reproduction hood. It does not fit well on the back edge. At the back center, it has a height of 9/16 ". An original is approx 1/4". A potential remedy is to split the inner skin from the outer skin and rebond it correctly aligned to the cowl. The edges do not, however, have a clear demarcation between the skins. It appears to be a solid piece. Has anyone tackled this type of project? In other words, any suggestions for properly separating the skins without a visual border between them? Given that the edge appears to be a "solid piece", might another alternative be to merely sand the top down to specs? Thanks.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11334
    Re: 58 hand laid reproduction hood
    Richard,
    Are you saying that the fiberglass thickness is 5/16" more than it should be, or that there is a bow in the hood running from left to right resulting in the high spot?
    I believe that even the hand laid hoods are made up of 2 pieces, top surface bonded to a separate frame.
    In my opinion I don't think it's a good idea to grind down the top surface to solve the problem. You would loose the even surface and getting it to look right could be a time consuming task.
    Was this a used hood or a new one from Ecklers? I ask because I'm waiting for a '59 hand laid nose and hood from Ecklers and concerned about having the same issue as yours.
    Rich
    • Richard H.
      • March 1, 1985
      • 241
      Assuming an original hood has a edge height of 1/4" in the middle of the back edge, mine is 9/16". This hood is more that 8 yrs. old.
      • Edward L.
        • 278
        Before you start separating, grinding, etc., try the following:
        Support the hood on the outer edges leaving the middle suspended. Place weight on the trouble area, ( I used cinder blocks ) then apply heat from a heat gun to the bowed area. It will move! Take some measurements. Soak a towel with cold water and cool the area. You may have to do it several times to get it where you want.
        I did this a few months ago on a '57 hood. The bow I had was worse than what you describe.
        Good luck.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11334
          I just measured my 59 hood, and a 59 hood from another car. They are both 1/4".
          Rich
          • Richard H.
            • March 1, 1985
            • 241
            Thanks. It would be nice if when restoring these cars everything would just "snap" into place. There seems to be a 1001 issues like this; doesn't make things easy.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11334
              I know your pain. Read my recent thread about '63 vent window and door seals and channels. OMG I'm ready to have a migrane, pinched nerves, and a nervous breakdown!
