1962 Front Wheel Cylinders - NCRS Discussion Boards
  • David J.
    Infrequent User
    • May 31, 2000
    • 28
    Does anyone have a current AC Delco part number for the front right and left wheel cylinders on a 1962 corvette?
    David
    • 6960
    Re: 1962 Front Wheel Cylinders
    David, I dont know if you have the original wheel cylinders in you 62, but I brought a set of rebuilding kits for for a 59 I did this past summer, there easy to do, as long as the bores are not pitted to badly, I was able to hone the cylinders out and replaced the seals.
    As far as Delco goes these days there not the same as they use to be,you can go to your local parts store and purchace a set, and they may be the same as the Delco ones, they do alot of reboxing parts today.
      • 43289
      David
      David------
      As far as I can tell, there are no currently available GM or Delco wheel cylinders for your application. As Edward has mentioned, even if there were Delco-available cylinders, they would almost certainly be the same product as sold under other brand names in a Delco box. No GM or DELPHI entity has manufactured these wheel cylinders in MANY, MANY years.
      As a matter of fact, you may even have problems finding these wheel cylinders under most other major brands. The only brand that I can find that currently offers them is Dorman. In this brand the front left is W14493 and the front right is W14494.
      As Edward also mentioned, it's very possible to rebuild what you have. Even if the bores are damaged, they can be stainless steel or brass sleeved, just like 65-82 calipers. With new pistons and seal kits installed, you'd have better-than-new wheel cylinders.
      • David J.
        Infrequent User
        • May 31, 2000
        • 28
        I have the originals and plan to have them rebuilt some day. One of the front cylinders has a stuck piston and the other has bad pitting. I have been surfing trying to find a reputable company to rebuild the old ones; I heard that I need to watch out who I send them to. Can you recommend a business that does a good job of a complete rebuild including new sleeves and new pistons?
        David
          • 6960
          David,have you looked in the driveline? also I know that paragon does alot of rebuilding of original parts.
          • David J.
            Infrequent User
            • May 31, 2000
            • 28
            Thank you for the help guys!!!!
            David
              • 6960
              David.T ran across this web site which does wheel cylinders resleeving, www.applehydraulics.com.
              • David J.
                Infrequent User
                • May 31, 2000
                • 28
                Thank you for the info and the link.
                David
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17969
                  David, CSSB is a long time NCRS Driveline advertiser and I've used their products many times with success. Gary....
                  Explore top-quality brake parts for a smoother and safer driving experience. Contact us for more information.
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                  • David J.
                    Infrequent User
                    • May 31, 2000
                    • 28
                    Thank you for all the help and links, you made my day.
                    David
                    • David H.
                      • November 11, 2009
                      • 777
                      Interesting......
                      I went looking for the original part numbers for the wheel cylinders and came up empty in the AIM and the Service Guide and even in the Judging Guide. Nothing even mentioned in any of them about the brakes at the wheels. Wheel cylinders, shoes, hardware, nothing!
                      Why is that? Just curious.
                      If you had a part number you might find one on ebay or other auction sites.
                      Just a thought. I am in the same boat.
                        • 43289
                        Originally posted by David Hurd (51036)
                        Interesting......
                        David-----
                        The wheel cylinders were part of the spindle or axle assemblies, so you won't find them shown separately in the AIM. I would think they would be depicted in the Chevrolet Service Manual, though, but no part numbers will be shown in that reference.
                        The original wheel cylinder part numbers for 1962 Corvettes were as follows:
                        front, left----GM #5459518 (may be cast 5459527)
                        front, right---GM #5459519 (may be cast 5459528)
                        rear, left---GM #5459918
                        rear, right---GM #5459917
                        • Mike E.
                          • February 28, 1975
                          • 5153
                          Joe's casting numbers are correct. Rears are both cast 5459965--just machined differently to get the different part numbers.
                          • John F.
                            • March 23, 2008
                            • 2424
                            Buy a set at O'Rielly's or other parts store and rebuild the originals at your leisure.
                            John
                            • Mike E.
                              • February 28, 1975
                              • 5153
                              John,
                              The point is you can't just go out to O'Reilly's or any parts store and buy 1 3/16 wheel cylinders. They and everyone else want to sell you 1 1/8".
                              That's why Joe indicated that there is only the one brand that sells those, and you can't find those just anywhere.
