Holley Carb Restoration-Part 13-Finished Assembly - NCRS Discussion Boards
  • Gerard F.
    • June 30, 2004
    • 3806
    Well I thought I'd close things out before heading to Kissimmee. Here's the finished assembly subject to adjustment before putting on the car:
    One question though. Which finish should be on the bowl vent lever for this 3810 dated 763:
    Should it be the natural zinc that is on the carb or the black phosphate one that is below.
    See you guys in Kissimmee.
    Jerry Fuccillo
  • Brian M.
    • February 1, 1997
    • 1842
    Re: Holley Carb Restoration-Part 13-Finished Assembly
    If it performs as good as it looks you hit a home run, see you in Fl.
