Re: 2006 Corvette with dead battery?
i found the fix on the fuel gauges is never try and add any more fuel once the gasoline pump shuts off because anymore causes the slider on the card to go up into a unused area of the contact surface and causes the problem. i learned this on my early C-5s and after i stopped trying to top off the tank i have had no more fuel gauge problems. also on the battery problems i set my DIC not to lock the doors unless i push the button. i had a friend whose battery was always going down and till i set his DIC to blow the horn when he locked and unlocked the doors. he did not know that the car in the garage under his kitchen where he kept the fob was going thru the lock and unlock routine every time he walked across the floor in the kitchen and the fob vibrated. he found this out because now the horn would blow.
