I'm looking for help in determining if my 67 427 3x2 accelerator rod is original or a reproduction. It has the "MW" stamped on it. It also has no marks at any of the bends. The spring clip has one large weld. It appears to have never been gold cadmium dichromate plated. It appears to be zinc silver plated. If original I'd like to get it replated correctly. Attached are some images.
67 3x2 Accelerator Rod Help
Re: 67 3x2 Accelerator Rod Help
The "MW" logo looks identical to the "MW" logo on my original 1966 Corvette w/327 accelerator rod. I do not believe that the reproductions have this logo.
The original swivel (GM # 3758592) measures 1.08" overall. The 0.43" dia. part of it measures 0.52" long and the 0.25" dia. part of it measues 0.56" long. There is also a very thin groove located just below the rim of the 0.43" dia. flat section. There is also a tiny dimple in the center of the 0.43" dia. flat section.- Top
Some additional pics.- Top
Here's what's on my reproduction (purchased early '90's; can't recall vendor). The threaded section is 1_7/8", which appears to be longer than yours. The clip is welded (soldered ?) on in the same orientation; ie. points vertically down when installed, but there's some weld/solder that oozes out each side (clip dimples might have been added for cosmetics). There are 4 crimp marks along the length (from bending tool). No MW stamping. Definitely not gold-cad plating. Clip is 1.75" from the hole center to the center of the next forward bend.I'm looking for help in determining if my 67 427 3x2 accelerator rod is original or a reproduction. It has the "MW" stamped on it. It also has no marks at any of the bends. The spring clip has one large weld. It appears to have never been gold cadmium dichromate plated. It appears to be zinc silver plated. If original I'd like to get it replated correctly. ....
Repeat -- mine is definitely repro.
- Top
Thanks Bob and to all who responded. I think I'll leave the part as is with the zinc silver plated finish even though I've never seen a high quality restoration with an accelerator rod without gold dichromate plating. I have an early car and maybe the supplier made a change at some point.- Top
Dereck:
Maybe the gold was over top of the zinc and just wore off with time. As mentioned, mine looks exactly like yours in color and I know it was original on my car.
I changed mine for the reason you said about the cars you have seen all being gold.- Top
I thought that rod was supposed to be cad or zinc? I don't remember the gold color. I may be wrong though.....Thanks Bob and to all who responded. I think I'll leave the part as is with the zinc silver plated finish even though I've never seen a high quality restoration with an accelerator rod without gold dichromate plating. I have an early car and maybe the supplier made a change at some point.- Top
