69 speedo cable - NCRS Discussion Boards
69 speedo cable
  • Jim M.
    • February 23, 2009
    • 233
    69 speedo cable
    Is it possible to change out the speedometer cable without removing the left hand dash panel? I just received a new cable from one the usual suppliers and noticed that the speedometer end does not have the screw on connector. it looks as though it must push on.
  • Tom L.
    • October 17, 2006
    • 1439
    Re: 69 speedo cable
    Try this... http://www.corvettemagazine.com/2000...le/speedp1.asp
    • Jim M.
      • February 23, 2009
      • 233
      Re: 69 speedo cable
      Thanks Lynn, that article really helps. jim
        • 43290
        Re: 69 speedo cable
        Jim------
        1969 uses a snap-on type connector at the instrument end, but a screw on connector at the transmission end. You might be able to remove and re-install the connector without removing the dash panel. More likely, you'll find that it's frustrating enough that removal of the dash panel will begin to sound good to you.
