Cruise Control Update - NCRS Discussion Boards
  • Jack P.
    • March 19, 2009
    • 1135
    Hi, a few months ago I asked the question what to do about cruise control on my 66 L79 roadster.
    The response was to try the " Audiovox Cruise Control unit : CCS 100 universal kit.
    See this post if you can, for other comments on unit:
    http://forums.corvetteforum.com/c1-a...e-control.html
    I ordered the kit and installed it last night. Very easy installation , I have attached photos. I put all wires through firewall. I have a cut off switch to neg. distrib wire on inside of car firewall. I ran the blue (unit coil wire) into cabin and attached to my coil wire near switch.
    If you have a small block you can see the unused firewall cap just above the clutch shaft. I drilled 1/2 hole and ran convoluted wire hose supplied, through hole.
    The kit sell on Amazon.com and other sites for anywhere from $89 to $165 for same unit. So shop around before you buy.
    It is the greatest thing since apple pie. It works just like it promises and as you read the other post with comments and directions.
    Just like a factory control. I used the dash switch, but you can buy a turn stalk if you like. Kept speed within a mile or two of setting.
    Addition to directions in kit and other post:
    Set dip switch # 4 to on position for high performance cars. You can experiment with the sensitivity, if it pulls too fast or too slow you can change it.
    Put dip switches to 8000 rpm also not 4000 as stated.
    If your legs or back hurt from lack of movement and you need to move you feet around, this does the trick just like your modern car.
    I took the car out this morning..... 8* but sunny, drove 100 miles up and down Maine Turnpike. It was heaven. I have a 3.70 rear and with the cruise control, I don't feel like I am driving the car with my gas foot. You know how tiring it is on you leg to keep always giving it gas.
    Have fun and see you this summer, see map.
    http://maps.google.com/maps/ms?hl=en...,86.044922&z=4
    PS Don't make fun of my scruffy console and yes I know it is not original, but boy, does it (Cruise Control ) make it easy to take long drives.
  • Don H.
    • December 1, 1981
    • 1487
    Re: Cruise Control Update
    I have used bolt on cruise controls on three mid years going back thirty years. When I installed it on my current '65, I tried to "hide" it more than the past. A couple of things I did different were: Attach the servo cable at the rear of the linkage going to the carb (mostly covered by the shielding), Put the servo as high as possible in the inner fender area, Control attaches to the turn signal lever - I keep it rolled up under the dash & only attach when using. I can take some pictures if you are interested. Don H.
    • Jack P.
      • March 19, 2009
      • 1135
      Hi Don, If you get a chance to take pictures, please do. CC makes driving these car some much more comfortable. I should have done it 30 or 40 years ago. I have attached a picture with air cleaner on.
      Jack
      • Jim T.
        • March 1, 1993
        • 5351
        I used my 1970 as a daily driver and accumulated about 150K (lots of cross country trips) on it by the late 80's. Wish it could of been ordered with cruise, that would of been great.
        I did buy a cruise control to install it in the mid 80's that I hope to install one day.
        This complete cruise control is for a Chevy Nova and the complete unit is a add on purchased over the counter at my Chevrolet dealer. Everthing is included in one box to install it. It uses a dash mount switch button to activate the cruise.
