Dipstick "green Dot" W/dimple - NCRS Discussion Boards
  • Russell L.
    • January 1, 2003
    • 43
    I have a dipstick with a green dot button round with dimple. on the stick it says "USE SE ENGINE OIL". There is a part number of 3951576 with the letter "M" after it. What is the application for this dipstick and is it original or service replacement do you think?
  • Larry E.
    • 1692
    Re: Dipstick "green Dot" W/dimple
    Hello:
    This came up on the Camaro Discussion Board; here is what it said:
    The dip stick sold by GM under 3951576 with 3876870 tube will work for your 1971 Z28
    The current GM 3951576 dip stick uses the green tip handle with the dimple and is the same length as the original green tip handle used
    during assembly line production
    Current stick is stamped with GM part number "3951576" and "USE SE ENGINE OIL" and has a dimple in the handle
    1969-71 assembly line production dip sticks are stamped with "USE GM6040 M QUALITY MS OIL" without GM part number
    and no dimple on the handle
    The 3876870 tube remains the same with no changes
    Larry
    Larry
    LT1 in a 1LE -- One of 134
    • Russell L.
      • January 1, 2003
      • 43
      Larry, thanks for the post. I guess that this dipstick would be correct for any 69-71 chev camaro including Z-28 or would it only be used for Z-28 application?
        • 43250
        Russell-----
        The GM #3951576 was used for a very large number of small block applications over the 1969-79 period---far too many to list here. It is also SERVICE for 1967-68 Chevelles with small block. As far as Corvettes go, it was used only for 1975-E76.
        The dipstick you have sounds like an older SERVICE piece. I don't think that originals or original SERVICE pieces had the dimple. The version of the 3951576 available for the last 15 years, or so, has a yellow plastic handle. So, what you have is a lot closer to original configuration than what you can buy now.
        • Russell L.
          • January 1, 2003
          • 43
          Thanks For All The Input, Russ
            Russ -
            The '69 Z/28 dipstick didn't have a plastic plug - just a flat rolled handle. Photos below of my original (02D Norwood car).
