Alum. Rad and Fan & Shroud: What's it fit? - NCRS Discussion Boards
  • Norman S.
    • September 30, 2002
    • 69
    I have acquired an Aluminum Rad with the following numbers stamped: 3155316 65J
    Also have a Fan & Shroud with mounting clips with a
    white stenciled number: 4266938
    Would like some help identifying the application.
    Thanks.
    Norm
  • Gary B.
    • February 1, 1997
    • 7053
    Alum. Rad: What's it fit?
    Norm,
    According to DeWitts that radiator is correct for Corvette for 1960 and 1961 up to VIN 1700.
    Gary
      • 43247
      Re: Alum. Rad: What's it fit?
      Originally posted by Gary Beaupre (28818)
      Norm,
      Gary
      Gary and Norm-----
      I think you might have mis-read the DeWitts page. The GM #3155316 radiator was used for all 1963-67 Corvette small blocks and some 1968-72 small blocks.
      • Lynn H.
        • December 1, 1996
        • 514
        Re: Alum. Rad and Fan & Shroud: What's it fit?
        Thanks.
        Norm
        Pictures would help for an exact ID on the shroud.
        Lynn
        • James G.
          • May 31, 1976
          • 1556
          Thanks.
          Norm
          it is a 1965"J" RADIATOR production date 'J' = October, so the radiator is for more than likely a November 1965 production 1966 small block Corvette, vin number 4384 to 7126. Parts were usually 2-6 weeks before the cars production. You probably have an old original radiator that was no good and replaced.
          Now, is fan shroud metal or fiberglass ?
          • Gary B.
            • February 1, 1997
            • 7053
            Gary and Norm-----
            Yup. I misread the DeWitts webpage. Joe, you're correct, as usual.
            Gary
              • 43247
              Gary
              Gary------
              Now don't start getting the idea that I'm always right, because I'm definitely not. If I was, I wouldn't need to come here to get myself "straightened out".
              • Gary B.
                • February 1, 1997
                • 7053
                Gary------
                Joe,
                You may not always be right, but percentage-wise, you are way up there.
                Gary
