63 FI unit - NCRS Discussion Boards
63 FI unit
  • Gary P.
    • May 31, 2005
    • 104
    63 FI unit
    I would like to know if the fitting on the back of the dog house for power brakes is black or brass. Jan, car.
  • John D.
    • December 1, 1979
    • 5507
    Re: 63 FI unit
    Gary, Power brake Fitting is bare brass on your Jan car or any 63 for that matter. You didn't ask but the branch T fitting on the main diaphragm cover is bare brass also
    Now the PCV fitting on RR of plenum was typically cad plated although a few original blackened ones have been seen.
    The 90degree fitting on top of the air meter should be cad although some guys make this fitting black which is questionable. Real early 63's may have bare brass PCV 45degree fittings.
    The 90 fitting on the bottom of the enrichment diaphragm cover is cad also. The 1/8"pipe fitting that screws into the front bottom corner of the plenum is cad plated. JD
    • Gary P.
      • May 31, 2005
      • 104
      Re: 63 FI unit
      Thanks John, my pcv and air meter fittings are black. I'll leave the booster fitting brass.. Gary.
      • Michael H.
        • January 29, 2008
        • 7477
        Re: 63 FI unit
        JD
        Power brake fittings can be either natural/brass or cad or zinc.
        Never seen an original black PCV valve fitting. Brass or zincad.
        • John D.
          • December 1, 1979
          • 5507
          Re: 63 FI unit
          Michael, I have never seen a cad or zinc 63 power brake fitting. But I bet you have pics to back this up.
          On second thought.
          Actually I did see one plated and thought that a former restorer did it. Interesting. Thanx, JD
          • Gary P.
            • May 31, 2005
            • 104
            Re: 63 FI unit
            Michael,
            They did make black pcv values. Gary.
            • Michael H.
              • January 29, 2008
              • 7477
              Re: 63 FI unit
              Originally posted by Gary Parris (44071)
              Michael,
              Yes, the 63 PCV valve was definitely a black 590. The 45* fitting that it's screwed into, though, was either natural/brass or zinc plated brass.
              • John D.
                • December 1, 1979
                • 5507
                Re: 63 FI unit
                Michael, How about an educated guess when you think the fitting went from bare brass to cad or zinc plated. JD
