1970-1972 hood support bolt headmark - NCRS Discussion Boards
  • D S.
    • March 1, 2005
    • 1551
    What headmarking(s) were on the 1970-1972 hood support bolts? I've read posts that some had anchors, some had E, some had B. Mix and match? I know the configuration is hex head and cone shaped at the one end with a loose washer.
    Scott Sims
    Texas Chapter
    • 6942
    Re: 1970-1972 hood support bolt headmark
    Scott, my 72 coupe has two zinc plated anchor bolts with built on washers indexed head on the hood, the one on the fender and lower attachments are RWB black phosphate indexed head and the fender had a zinc plated square washer under that fender bolt.
    • Michael G.
      • March 2, 2008
      • 485
      Scott, I found the upper hood bracket attached by the indexed head, captive spit ring lock washer bolts. Upper had the anchor, and the other had a circled E with three lines coming out. one at the top, bottom and open end of the E. The lower attachment was the larger bolt with indexed head, flat washer over a rectangular plate that sat in the drain channel of the fender. This had the uncircled C with the lines coming out at the top, bottom, and closed side of the C. This is a Dec.-70' built 71'. Mike
      • D S.
        • March 1, 2005
        • 1551
        Thanks, Edward and Mike. Sounds like one of those assembly line things where whatever bolts were in the bins then those were what were installed. The ones with the C on them seems to be the most used as evidenced by what is on eBay as "correct". I'm awaiting more input though. I am most particularly interested in the two bolts mounted to the support flange on the inner fender.
          • 15601
          Now you've got it. That applies to almost all the fasteners on the car.
          Please, don't ever use eBay to judge what is correct. Daymn! You've been around here long enough to know that.Or did I miss the humor in your statement. Humor =
          • D S.
            • March 1, 2005
            • 1551
            I know, Terry....what was I ever thinkin'? Every one of those hood support bolts on eBay are deemed "correct". Hope to see you again, soon.
              • 15601
              And so is everything else "correct" on that site.
              CU in a week.
                • 15601
                Scott Sims
                Texas Chapter
                Scott,
                The two bolts into the hood are Anchor on my 1970. The one into the drain gutter is C in a circle. There is no way on earth any judge is going to see the headmark on the other two -- nor can I.
                  • 11643
                  You gotta be careful what you wish for.
                  FYI, the AIM, as well as my own inspections, show all 3 shown in the photo to be the same bolt (actually, screw per the AIM).
                  • D S.
                    • March 1, 2005
                    • 1551
                    In eBay's Adult section, too.
                      • 15601
                      Your vacuum hoses are routed differently than mine -- not too surprising given the different years of the cars. My vacuum, and wire harnesses block those lower bolts.
                      • D S.
                        • March 1, 2005
                        • 1551
                        Terry, my vacuum hose routing is the same as yours and Patrick's and I can't see the headmarks on my lower support flange. I also own a 1970. The Corvette in question is a 1972 so I guess the vacuum hose routing is somewhat different. I have a small, round extendable inspection mirror that I might be able to squeeze in there to see the headmarks on mine.
                        I do appreciate the photos and input from all.
                        • Chuck S.
                          • April 1, 1992
                          • 4668
                          ...The two bolts into the hood are Anchor on my 1970. The one into the drain gutter is C in a circle. There is no way on earth any judge is going to see the headmark on the other two...
                          On my car, all three screws attaching support to fender have the same head mark as the one in your gutter. The two attaching the support to the hood are zinc plated anchor like yours.
                          Since yours is very early 70, and mine is very late 70, I would say that for a 70, those head marks would be primo choices.
                          • Dave S.
                            • August 31, 1992
                            • 2925
                            These are from 70 VIN #14803 - July 8 car. I can't clearly make out the head markings on the lower two bolts but I think they are grey phosphate Anchor head with pressed on washers. Obviously the "E" head has no plating and the two bolts on the upper end are cad or zinc plated.
                              • 15601
                              I would bet my lower two were either no plating or gray based on their condition. I can try again with a mirror, but given the temperature I will probably fog it up before I see anything.
