Bair's C2 Repro Half Shaft, Drive Shaft - NCRS Discussion Boards
  • Gary S.
    Super Moderator
    • February 1, 1984
    • 457
    Has anyone compared Bair's repro half shaft and drive shafts for C2's. They say they are made of extruded steel and no grease fittings. Restoring my 67 for judging and mine are badly pitted. Or...any recommendations?
    Thanks...Gary
    Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
  • Mike G.
    • July 31, 2002
    • 709
    Re: Bair's C2 Repro Half Shaft, Drive Shaft
    i put them on both my lt-1s. have not judged yet but i think they will do fine. i am not sure you can tell them apart.
    • Scott S.
      • March 1, 1979
      • 747
      Gary, Brian and Yogi are usually in Florida. Maybe they can bring a set for us to see. I am looking forward to seeing your tire tub/lid.
      Scott
      • Joel F.
        • April 30, 2004
        • 659
        Gary,
        I have seen half-shafts on cars with a finish I can only describe as "turned", where the body of the shaft has a grain that runs around the circumference of the shaft. I can't tell from the picture but these look like they may be those same shafts. You might check with Nick Culkowski for his thoughts, but I do not believe this is correct for any car, especially a big block.
        Joel
        • Joe R.
          • July 31, 1976
          • 4550
          Thanks...Gary
          Gary, I'm no expert in the field of steel but I did stay at a Holiday Inn last night. Actually I worked for US Steel National Tube Division in Gary back in the 60's.
          The original tubes are what's called "Cold Rolled". They have a weld seam the entire length of the tube. They are not as strong as extruded if made from the same steel but the Cold Rolled is more than enough for 500HP. The ones Bair's sells are excellent pieces but won't pass strict judging standards.
          JR
          • Gary B.
            • February 1, 1997
            • 7019
            C2 Repro Half Shafts; LIC has good ones
            The standard suspension (not shot peened) half shafts that LIC sells have the longitudinal seam and I believe they would receive full credit during judging.
            Gary Beaupre
            Northern California Chapter
            • Gary S.
              Super Moderator
              • February 1, 1984
              • 457
              I did ask Bairs to bring some for me to look at. Maybe some of you would like to take a look. Thanks for all your responses. Gary
