I am investigating a 68 L71/L89 roadster. The car is mostly mechanically original and low mileage, having been stored for the past 25 years. The tank sticker is present denoting the L89 option. The motor is a correct 4 bolt 3916321 block with a date code of J 18 7 (sept 18 1967) yet is stamped CE. From my understanding the CE block was most likely a warranty replacement. How much does this affect the value of the car ?
CE block price de-valuation
Re: CE block price de-valuation
The value is usually the same as any other NOM cars as there's no real proof that this engine was installed as a direct replacement for the original.- Top
Mike and Robert------
In fact, if I understand the way things work on this, a "CE" block might actually take more of a judging point "hit" than a non "CE" block. For instance, if the "CE" block were dated outside the 6 month prior window (as most will be), then it would take more of a "hit" than a correctly dated, non "CE" block even if the casting numbers on both blocks was the same and correct.In Appreciation of John Hinckley- Top
The only way to be sure that a CE block was installed under warranty is a repair invoice for the warranty replacement along with the correct ID numbers for the CE block that is in the car. In either case there is no difference in judjing. It is a NOM car.- Top
Right, it's just another NOM car. I recently looked at a 1967 L71 car (tank sticker, etc.), but had a '74 454 block in it. Obviously the price hit is very large for this (30-50%) from a numbers matching L71.Big Tanks In the High Mountains of New Mexico- Top
In fact, if I understand the way things work on this, a "CE" block might actually take more of a judging point "hit" than a non "CE" block. For instance, if the "CE" block were dated outside the 6 month prior window (as most will be), then it would take more of a "hit" than a correctly dated, non "CE" block even if the casting numbers on both blocks was the same and correct.- Top
I am investigating a 68 L71/L89 roadster. The car is mostly mechanically original and low mileage, having been stored for the past 25 years. The tank sticker is present denoting the L89 option. The motor is a correct 4 bolt 3916321 block with a date code of J 18 7 (sept 18 1967) yet is stamped CE. From my understanding the CE block was most likely a warranty replacement. How much does this affect the value of the car ?Lyle
I'm trying to digest the scope and direction of this entire thread. Sounds like most of you would pass on a very low production car(600) units with documentation (tank sheet) because it no longer has its original engine. Sounds like a great find to me.- Top
Joe------
I could not possibly agree more. These are the sort of cars that most folks should be SEEKING OUT rather than shunning. This is especially true if one's intention is primarily to drive and enjoy the car.In Appreciation of John Hinckley- Top
I agree with both of you, but my point is that the price should be heavily discounted due to the NOM state of the car, that's all. If it is newly totally restored, with original all other things, it is just not worth what a numbers matching car is worth. If it is a project car and you just want a driver, great, just don't pay premium prices for what it left the factory with that is no longer there.Big Tanks In the High Mountains of New Mexico- Top
