63 Idler pulley - NCRS Discussion Boards
63 Idler pulley
  • Michael G.
    • November 12, 2008
    • 2157
    63 Idler pulley
    The idler pulley on my L84 has a bad case of the wobbles. I'm thinking I'll replace it, but I'm not sure if the pulley should be black or silver on a late April car. Anybody know?
    Thanks, Mike
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 63 Idler pulley
    Thanks, Mike
    Mike,
    There are a lot of pic's of early production engines with an unpainted pulley but most were painted black in later production.
    The bracket was always painted black.
    • Michael G.
      • November 12, 2008
      • 2157
      Re: 63 Idler pulley
      Thanks Michael, my current one is black, but Paragon only had a silver one. ! I guess I'll look for a black one.
      Mike
      Mike
      • Paul Y.
        • September 30, 1982
        • 570
        Re: 63 Idler pulley
        If it is your bearing that is making it wobble, it is the same as the water pump bearing. Easy to find and replace locally.
        It's a good life!
        • Michael G.
          • November 12, 2008
          • 2157
          Re: 63 Idler pulley
          Paul,
          Its not the bearing, the pulley seems to be canted slightly on the shaft. I think it was probably a low-quality repop.
          Mike
          Mike
          • Douglas C.
            • September 30, 1988
            • 237
            Re: 63 Idler pulley
            I thought that someone (Corvette Central/Dr. Rebuild??) makes a repair/rebuild kit for these.
