71 LT-1 Holley Why were these in there? - NCRS Discussion Boards
  • Paul O.
    • August 31, 1990
    • 1716
    Re: 71 LT-1 Holley Why were these in there?
    Terry I do not have the carb any more but I remember 4801-A. The replacement and the original carb both had these blocks in the bowls. Paul 18046
      • 15599
      TX for satisfying my curiosity.
      • Jean C.
        • June 30, 2003
        • 688
        #18
        [quote=Clem Zahrobsky (45134);463152]....they were there to cut down on the amount of fuel in the bowls to cut back on evaporative emissions.
        Clem,
        Interesting stuff. Were the pieces installed in such a manner that they reduced the surface area of the fuel in the bowls? Otherwise, how would they serve to cut back on evaporative emissions within the bowls? Probably more to it than my gray matter can process . I reckon if the fuel in the bowls completly evaporated, there would have been less fuel to evaporate resulting in less evap emissions. Thanks.
        Best regrads,
          • 11643
          #19
          The lake effect is burying Patrick this winter.
          Yah.
          I'll be out with the snowblower early in the AM tomorrow.
          We've received several inches of it today.
          Patrick
          • Clem Z.
            • January 1, 2006
            • 9427
            #20
            [quote=Charlie Cadenhead (40193);463243]
            Clem,
            Interesting stuff. Were the pieces installed in such a manner that they reduced the surface area of the fuel in the bowls? Otherwise, how would they serve to cut back on evaporative emissions within the bowls? Probably more to it than my gray matter can process . I reckon if the fuel in the bowls completely evaporated, there would have been less fuel to evaporate resulting in less evap emissions. Thanks.
            Best regrads,
            they fit into the cavities of the metering bodies so i would guess that they would cut down on the amount of area that heated up the fuel when you shut off the engine as they would act as a insulator.
