Electronic Tach conversions - NCRS Discussion Boards
  • Lorne G.
    • June 30, 1988
    • 118
    My 67 BB distributor is worn out and causing premature tachometer cable wear. The gear is chewing up the cables.
    Rather than rebuilding my old distributor I was thinking about using an aftermarket distributor that I have lying around that does not have a tach drive. To make the tachometer functional I was considering converting my mechanical tach to an electronic version. I see a few dealers like Roger offer this electronic conversion.
    Does anyone have any experience with these new electronic conversions?
    I welcome any feedback positive or negative. Thanks.
    Lorne
    Re: Electronic Tach conversions
    Lorne -
    Have you inspected the mainshaft gear and cross shaft gear? Is the square hole in the end of the cross gear where the cable end inserts rounded-out? It's a whole lot easier to replace the cross gear (or to rebuild the distributor) than it is to pull the cluster and send it out for a tach conversion. Dave Fiedler has an excellent article on rebuilding tach-drive distributors on his website (www.tispecialty.com).
    • Lorne G.
      • June 30, 1988
      • 118
      John, Thanks for rebuild article. I haven't had a chance to thoroughly inspect the distributor yet but I would believe a complete rebuild would be in order.
      I have removed the cluster to replace various bulbs and disconnect the tachometer. Since the cluster is out I am looking at all options including the tach conversion.
      I would be interested to see if these conversions are getting popular and if they provide any benefits.
      Lorne
