Fuel Lines For 68 427/390hp - NCRS Discussion Boards
  • Jeffrey A.
    • October 22, 2006
    • 273
    I am looking for help on the fuel lines from the carb to the fuel filter then from the fuel filter to the fuel pump. According to the assembly manual the fuel filter bracket is mounted AIR Pump bracket ( Therefore the filter is set off the block a few inches). Can anyone share any correct dimensions of these lines and/or post a pictures so I can look at the configuration as well. My car is 427/390hp 4 speed with a/c. Thanks Jeff
  • Reba W.
    • 937
    Re: Fuel Lines For 68 427/390hp
    http://www.corvette-paragon.com/p-35...427390-hp.aspx
    • Brandon T.
      • October 23, 2008
      • 872
      If you need anymore help with this (looka likw the above link is what you need) just let me know I also have a 68 l36 and would be glad to post pictures for you.
      • Jeffrey A.
        • October 22, 2006
        • 273
        Hi Brandon, I did order get a set of them and they do not fit. Could you please a picture of your set-up for me to review. The top line the sell from the carb to the filter is to short. If the fuel filter bracket was not connected AIR pump bracket then it would work. I also had Richard Fortier make me a set and he is stumped as well. Thats why I bought the lines from paragon because richard wanted me to see if they would work.
        • Dennis S.
          • April 1, 2004
          • 228
          This fuel filter bracket is mentioned in the '68-'69 TIM & JG on page 55 for all Rochester-carburetor-equipped cars. This may not be correct. The '69 AIM does show the bracket on small blocks, but does not show it on the L36. l bought the bracket from Paragon, but cannot find any way to make it fit either. This has been discussed before.
          https://www.forums.ncrs.org/showthre...acket&uid=3277
          • Jeffrey A.
            • October 22, 2006
            • 273
            Dennis, thanks for the posting, this is a very interesting subject that has me stumped why the lines will not work for the 427/390 engine. The set of line I purchased from Richard Fortier and the set I bought from paragon are the same in configuration and lenght, The difference is that Richard line material is correct. If anyone has had there 68 L36 car judged and would kind enough to explain what is the correct thing to do, I would really appreciated it. If someone could post a picture of the correct configuration that would be great too. To me, after reading all the previous postings, I am not certainly alone on this issue, but there seems there is no really clear direction on this. Any input what to do is welcomed. Help. Thank you Jeff
            • Terry B.
              • August 31, 1999
              • 607
              Jeff,
              I think these are the pictures you are looking for. The bracket for the fuel filter does not fit and has been left off. Hopefully this will be addressed in the next edition of the '68 / '69 TJM if we ever get started.
              Let me know if you need other pictures.
              Terry Buchanan
              Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
              Corvettes Owned:
              1977 Coupe
              1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
              2003 Electron Blue Coupe
              2019 Torch Red Grand Sport Coupe
              • Brandon T.
                • October 23, 2008
                • 872
                Last in the game..but looks like someone provided some good pictures for you.
                • Dennis S.
                  • April 1, 2004
                  • 228
                  Jeffrey, I noticed in the '69 AIM that there is a clip holding the metal lines together beneath the fuel filter. It was not in Terry's pictures, so check the '68 AIM. I am sourcing one for my car right now.
                  • Jeffrey A.
                    • October 22, 2006
                    • 273
                    Guys thanks you very much on the help in this matter. This has been a really pain trying to figure what is correct. Terry, the pic were great. I really appreciate the the help. My car if all goes well is scheduled to be judge in June at the chapter level, My ultimate goal is to have it judge at a national meet. Thanks -Jeff
