69 shift boot - NCRS Discussion Boards
69 shift boot
  • Jim M.
    • February 23, 2009
    • 233
    69 shift boot
    I just received a new 4 speed shift boot and starting to think about the best way to install. It looks to me, that in addition to taking the console apart, the "T" handle must go as well to get the new boot over the shift lever. Is that correct?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 69 shift boot
    The T-handle is easy to remove. Just remove the shifter ball to remove it and pull it up, don't loose the spring.
    If the lower boot/seal is old, it also might need replacing.
      • 6940
      Re: 69 shift boot
      Jim, you are correct, just be careful with the fiber opitic,s. The cross over brace on front of console, the nuts can be a pain to remove use a flexable socket to ease the removel. if you have the vent cables its a pain to un-hook, A/C cars maybe alittle easier. lastly once your ready for the fiber opitics remove the two phillips head screws on the console,instead of unhooking, that way may break the fiber opitics, lift the rear part of console to access the small phillips screws.
        • 15595
        Re: 69 shift boot
        Ed I don't know which Jim you are referring to -- But Jim T has the right steps. I have replaced the shift boot on a 1969, and a 1971 without removing the console.
          • 43211
          Re: 69 shift boot
          Terry------
          Yes, all you need is a "stubby" phillips head screwdriver or 1/4" drive ratchet with phillips head driver.
          • Sal C.
            • December 1, 1984
            • 430
            Re: 69 shift boot
            I agree, as long as we're talking about the "upper" shift boot. Trim plate would probably have to come off to replace the lower boot.
              • 43211
              Re: 69 shift boot
              Sal-------
              If someone can get the lower boot off without first removing the trim plate I'd be TOTALLY FLABBERGASTED!
              By the way, for those that are unaware, the lower boot is really the important one. It's the one that seals out the weather and, more importantly, any fumes. The upper boot is pretty much "secondary" and, mostly, ornamental. Any fumes getting by the lower boot will enter the car even if the upper boot actually seals well.
              • Tom S.
                • March 1, 2004
                • 1087
                Re: 69 shift boot
                I agree with the above posts. All you need tool wise is a phillips screw driver. It is an easy job. Tom
                  • 6940
                  Re: 69 shift boot
                  Jim Mc. my post is for the lower boot, sorry for misleading you. Ed J.
                  • Jim M.
                    • February 23, 2009
                    • 233
                    Re: 69 shift boot
                    Thanks everyone, I'm heading out to the garage to give it a shot. Mac
                    • Dennis S.
                      • April 1, 2004
                      • 228
                      Re: 69 shift boot
                      The lower boot can be a bit of a PITA. The 6 hex head screws hold the top plate down, but you need to engage the two clips on the underside, inside the transmission tunnel.
                      • Jim M.
                        • February 23, 2009
                        • 233
                        Re: 69 shift boot
                        boot install was easier then I originally expected. thanks again. mac
                        • Mike D.
                          • July 31, 1996
                          • 304
                          Re: 69 shift boot
                          Mark Hambelton told me you bought another car but had no details. Send me some pictures.
                          Mike Doty
                          Intermountain Chapter Judging Chairman
                          Region VIII Director
                          • Jim M.
                            • February 23, 2009
                            • 233
                            Re: 69 shift boot
                            Sorry Mike, not sure who you are or who Mark is? I knew a Wes Doty. mac
