1954 6 volt starter - NCRS Discussion Boards
1954 6 volt starter
  • Ted K.
    • August 31, 1994
    • 337
    1954 6 volt starter
    Is the starter for a 54 Vette the same as a 54 Chev passanger car? I know it will fit but are the specs. exactly the same ( bigger coils etc).?
    Ted
  • Lynn H.
    • December 1, 1996
    • 514
    Re: 1954 6 volt starter
    Ted,
    My older parts books shows that the 50-54 pass w/PG, and 54 -55 Corvette (6 volt) were serviced with the same part number 1929912 (1108035 on n/plate). The NCRS spec guide shows two different 54 starters depending on when our car was assembled. The 53-Early 54 starter (two coil design) was 1107109, with the 54 Late 55 6 volt four coil design (entered production Feb 54) as 1108035.
    Lynn
    • Ted K.
      • August 31, 1994
      • 337
      Great info. Does anyone know if the four coil starter has any more zip than the two coil. My reason for asking is I am disappointed with my starter, which has been rebuilt but still lacks any zip. (2 coil)
      All connections are with the proper gague wires.
      Does anyone know where one can purchase a new or remanfactured 6 volt starter that would be to correct specs, none on e-bay or local parts houses?
      • Lynn H.
        • December 1, 1996
        • 514
        Ted,
        I can only assume this may have been the reasoning behind going to a starter with more coils. I would suggest speaking with someone directly at a starter/alternator rebuild shop if you have one in your area. I think not only can they do a "stock rebuild", they may also be able to "juice it up" without losing any of the original appearance (if your starter is original and numbers matching for your car). I am not 100% certain of this in this application, but I seen it done with some of the later model components.
        Lynn
        • Ted K.
          • August 31, 1994
          • 337
          The local folks just rebuild with over the counter parts. Does anyone know of a shop that might "juice up" 6 volt starters.
          Also where might one get the specs. to put a meter on the starter to see if it is performing as it should?
          Ted
          • John P.
            • August 31, 1991
            • 94
            The 2 coil starter has a history of tending to be weak.It can be built with aftermarket "super torque"fields. This is a substantial improvement and does not alter the appearance.The stock 4 field unit also tends to be slightly weak, and can also be upgraded. Make sure you have a fully charged "healthy" battery,and that all your wire connections are clean and tight.
            • Steven B.
              • June 30, 1982
              • 4011
              Ted
              Ted, John Pirkle can probably do it for you. I have two starters, a generator and an alternator from them and I am more than pleased with appearance and performance.
              Steve
              • Chuck G.
                • May 31, 1982
                • 2039
                FWIW, AND not to detract from John Pirkle, who does a marvelous job on all of his restorations..............................
                Let me say that when I owned my 54, I had the same problems. I had a local electrical shop rebuild my 2 pole starter with 4 Hi Torque field coil windings. They also "tweaked" the armature somehow.
                I lived in a fairly rural area in Maryland, and to this day, a lot of agricultural equipment is 6 volt. So....check around. You might find a "local" to rebuild and tweak the starter for you, one who has access to 6 volt "stuff".
                You might begin by calling some farm supply places. You can also buy extra "hot" 6 volt tractor batteries, which just happen to slip right in to the 53-4 battery tray. They're not cosmetically correct, but they work well. I used to buy them from Southern States.
                The high torque 4 field coil starters will make a difference.
                Chuck
                • Ted K.
                  • August 31, 1994
                  • 337
                  Sounds like the high torque coils is the way. Thanks for all the info.
                  I have also tried the 8 volt tractor battery, it works well when fully charged but the charging system would need to be adjusted to keep it fully charged, which I am reluctant to do.
                  Ted
                  • Troy P.
                    • February 1, 1989
                    • 1284
                    Make sure you have the correct battery cables. I have seen many that are too small a gauge for the 6V application.
                    You need a 1 AWG positive cable. If you not going to be judged you can get one at NAPA. If you are going for judging I may be the only one that makes the correct cable as pictured in the Judging Guidelines. Note: The "exact" cable sold by a popular supplier of 53-55 parts is far from exact.
                    On your negative cable make sure to sand/scrape/grind the paint off the contact area as indicated in the AIM before you bolt the cable to that grounding point.
                    • Tim E.
                      • April 1, 1993
                      • 360
                      The NAPA part number is 711431....I wrote it down from a previous thread on the 6v battery cables. As I recall, there was a lengthy discussion on the need for the 1 AWG cable and many people who experienced weak cranking as a result. Tim
