lower radiator/fan shroud - NCRS Discussion Boards
  • Al M.
    • February 1, 2004
    • 64
    OK, another question. I am trying to find out what the part is and what it is called that connects to the radiator support and to the fan shroud. There appears to be a place here for something. I don't have the part and need to identify it and purchase it.
  • Mike M.
    • May 31, 1974
    • 8381
    Re: lower radiator/fan shroud
    al, your 55 or 67? mike
    • Roy B.
      • February 1, 1975
      • 7044
      I've talked about that in an early post.
      And your the first person ever to ask about this.Repro suppliers only mention and sell a four piece Radiator shroud for 55 and 56 and don't realize there are FIVE pieces .Dave Ferguson was nice in sending me a drawing ,he has two different ones 1st design and later second design as seen here. It goes between the lower shroud and radiator support .When I see a 55 to 56 missing the two clutch head screw in the lower piece I know it's missing it (see lower pic).slotted holes. The JM don't mention it but if it ever gets done it will. The lower shroud having the two holes was carried over till it was changed .
      My guess is that the early 55 used the two angle supports (top pic), Left and right ,my 55 #401 has the large one piece support. Hope this helps you out.
      .The large support has a {S} logo centered .
      • Al M.
        • February 1, 2004
        • 64
        this is for my 55
        • Al M.
          • February 1, 2004
          • 64
          thanks Roy. I'm going to have to make this I think. I haven't been able to find it anywhere. the drawing helps.
          • Roy B.
            • February 1, 1975
            • 7044
            No one has or repro'ed it and if it gets into the JM some one will (may be me!) how's your 55 doing ? Roy
            • John S.
              • July 29, 2009
              • 640
              roy, excellent print. would be a easy piece for a person with a shear and break to reproduce! i'll also need one. has a point in production been determined for the change in bracket design? dave's 1064 and your 1401 is quite a gap. grossmueller's listed a "6 pcs-correct repro" radiator shrouding for a 55 v8. could they have fabricated the two early bracket parts?
              • Al M.
                • February 1, 2004
                • 64
                It's coming along Roy. Got the steering column in. Finished the wiring under the dash but still need to dress it. Tried the electrical and all is working correctly. I want to get my radiator area done so I can start the damn thing. But patience is a virtue.
                • Al M.
                  • February 1, 2004
                  • 64
                  I saw that about grossmuellers. I was going to call them.
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    John! Being the 55 is so rare and rarely ever seen there has been little afford to collect info on many things.Determining when the first and second design's came on line is a guess at this point on most parts. The 53 and 54 all things are known but 55 ?? I use production numbers between 350 to 400 that second design parts came on line ,but then that's just guessing. Dave Ferguson I rely on for some info because he has had so many 55's, his mind is like a mouse trap he remembers a lot, been friends for over 30 years. That's why I try to get info from 55 owners.
