TI distributors - NCRS Discussion Boards
TI distributors
  • Mike E.
    • February 28, 1975
    • 5141
    TI distributors
    What internal differences are there between TI distributors and regular Corvette tach-drive pointgsw distributors? I realoize the pick-up coil is different and the "rotor" is quite different. What else? The bodies are identical, aren't they? How about the shafts?
    Thanks!
    • 15625
    Re: TI distributors
    Body is the same as conventional distributor. Isn't the rotating trigger piece part of the shaft? It has been a long time since I had mine apart. The shaft will not have the lobes for the point block to rub on. The auto cam at the top (football shape) may be different as well.
    • Warren F.
      • December 1, 1987
      • 1516
      Re: TI distributors
      Mike,
      I would suggest going on Dave Fiedler's website. He explains the magnetic pulse transistorized distributors pretty well. TISpecialty.com
      • Timothy B.
        • April 30, 1983
        • 5199
        Re: TI distributors
        The body's are identical, the main shafts (except auto cam) are identical. The weight base/cam (rotating pole piece) is different along with pick up coil and brass spacer underneith.
        The weights and springs are interchangable between points and TI distributors for particular curve.
        • Doug F.
          • November 1, 1983
          • 322
          Re: TI distributors
          Mike, greeting from AZ, I wondered the same, so i bought a passenger car TI and converted a tach drive points distributor to TI, everything bolted up perfectly and fit just like i hoped it would, saved bunch of $$ to boot.
          • Mike E.
            • February 28, 1975
            • 5141
            Re: TI distributors
            Doug--
            You read my mind, didn't you?
